Some of my stuff...
Florian
I think its the best place to show you all my projects... ;)
This is the second steam engine i have built:
And here with additional displacemet oiler:
to be continued soon... ;)
very nice steam engine, could you give use some details on the engine (bore,stroke, flywheel size ect)?
a video of it running would be nice ;D
i noticed a very neat looking boiler in the last picture, did you build it?
keep up the great work.
chuck
Hi chuck
Here are the tecincal info's:
The base is from an old sewing machine which i once disassembled. When i saw the base i immediately thought that this would be the ideal base for a steam engine.
Bore is 28 mm, stroke something about 45 to 50 mm (im not shure anymore..)
The flywheel has 100 mm diameter and is 40 mm wide.
Some weeks ago, i modified my steam engine:
As im using this steam engine along with my scotch boiler and as my scotch boiler has a ckech valve for feed water, i also added an axle driven pump:
I will have to add a bypass-valve because the pump delievers too much water...
Florian
Of course i also have some videos:
[ame=http://www.youtube.com/watch?v=1zCsiKE7Y40]Video 1[/ame]
[ame=http://www.youtube.com/watch?v=lndSlx94H_U]Video 2[/ame]
[ame=http://www.youtube.com/watch?v=Bi1zKu__-A8]Video 3[/ame]
[ame=http://www.youtube.com/watch?v=javYbSHa8A4]Video 4[/ame]
With the windows directly inserted in the answer, it didn't work... so i've just put the links...
Florian
Some more infos about the boiler:
1. Its homemade...
2. The idea for this boiler has been educed from the principle of a scotch boiler, combined with some own ideas.
The boiler can be filled with one liter of water. The burner didn't work so well, i'll have to find another one which works better. (I have an idea, maybe i'm goning to build one by myself)
It takes in about 12 to 15 minutes to steam up
Working pressure is 3 bar, it has been tested by 4.5 bar during an hour. The reversing chamber is equiped with fireclay pieces to keep the heat inside.
The boiler seems to be very efficient, the exhaust gases are something about 150°C.
Florian
I have never built a boiler or run a model on live steam.
New inspirations here everyday.
Thank for sharing the videos Florian!
Rick
Rick
Wish I would have known that when I came out to see you... I would have brought my boiler with me. We could have fired up something!
Next time.
Eric
Did you guys think that's all my stuff?
;D
No.... I got a lot more to show you: :)
This is a small table plant i made for my godfather two years ago:
And now this november, i made another one for someone else, from here you will see the stepwise becoming of a tamble steam plant (nearly could call it a pocket steam plant... :big:)
The second engine has the following specifications:
bore: 8mm
stroke: 8mm
flywheel dia.: 25 mm, 8 mm wide
The wooden base is made from mahogani and is 10 cm to 14 cm
And of course, i have some videos:
blablabla
blablabla
Florian
That's some fantastic work there Florian, I love the boilers, how did you dome over the copper ends exactly?, it doesn't look like you just used a hammer.
Giles
I used a piece of wood (i don't know the word for it... its a template for driving sheet metal...)
And the hammer i used was a blow back proof hammer with plastic end caps.
Florian,
Can you provide more details about your burner design and the fuel that it uses.
Great looking project, I like the drip pan for catching the water droplets, clever.
Greg
The burner uses denaturated alcohol;
On the outside of the boiler housig, you can see the fuel tank.
In the housing, there is just a horizontal tube which carries two vertical tubes. In these two vertical tubes there is some cotton. I stupidly don't have any more photos because this engine also was a gift for someone.
Florian
Beautiful craftsmanship Florian, But we wouldn't be able to use Brass in the boiler construction in the UK. Regards Ian.
The outer casing and the fire tube that is, but nevertheless superb.
Circlip,
Because of the new 3bar/litre ruling in the UK, you could, in theory use a baked bean tin for a boiler.
The reason brass is frowned upon, is not because of its lack of strength, but because of its de-zincing qualities, where zinc is leeched out of the brass by hot water, and minute holes appear in the brass. There are now new breeds of brass about that don't suffer from this tendency.
Brass is still being used for low pressure boilers, as it has been since almost the turn of the 19th/20th century, by companies such as Wilesco and Mamod.
