A while ago I saw a small filing machine for sale on eBay. There were quite a few pics of it - enough for me to make a copy. One of the pics gave a partial view of the original design from the book 'Practical Benchwork for Horologists' and this gave a starting point with regard to size.
I've recently finished my version and given it a test. It uses needle files.
Usually, filing machines work with the cutting done on the down stroke but with this one the files cut on the up stroke. Using needle files there is not a lot of cutting force and so the job doesn't get lifted off the table. Another deviation from the traditional filing machine is that instead of a Scotch yoke system, this one uses an ordinary crankshaft and connecting rod. With the sliding members out of the way of the hole in the table, there shouldn't be too much filing dust dropping onto them.
The pillars are rods from an old printer and the sliding bearings are from a piece of phosphor bronze drilled and bored to give a slightly free clearance. I didn't want any binding and there will be no lubrication of the sliding parts.
The Emerald Isle
The Emerald Isle
