WhiskeyHammer
New Member
- Apr 27, 2014
- 4
- 2
Is there a simple/low-skill way of getting a near airtight sliding fit on a piston and bore?
I've been mulling this idea:
1) Get a pipe and rod made of the same material that are already pretty close to in ID and OD, the OD of the rod should be larger than the ID of the rod
2) Pop the rod onto a drill chuck and with a fine abrasive reduce, the OD of the rod as until it's a hand-strength press fit with lubrication into the shaft
3) With the rod still on the drill, press the pipe onto the rod, and start the rod spinning at very low speed
4) In my mind, the rod will lap itself against ID of the pipe and eventually you'll get your sliding fit
Will this work? Is there an easier way?
I figure there are a few guys here who've built some ringless pneumatic engines that might have worked out some better techniques.
