Just a couple of points V22 you are the only person to refer to hard soldering , the correct description for silver soldering .
Originally jewellers would use scraps of silver or even clippings from silver coins , generally silver solders contain at least 50% silver and have melting points above 650°C
Brazing is a method for joining ferrous metals with brass rod or wire , and should not be confused with sifbronze welding where commercially supplied bronze rod is used with oxy-acetylene to form a fillet joint between ferrous items .
In the former the job is heated above the melting point of the braze which then flows by capillary action into the joint , in the latter the localised heat of the flame keeps a pool of molten metal progressing along the joint rather like gas welding.
For those who are interested copper wire can be substituted for the brass if enough heat is available , borax mixed with water to a creamy consistency makes a cheap flux.
As already stated some solders containing a small amount of silver should be called soft solder , the bulk will be lead , tin or bismuth depending on its age or origins.
