terryp
Active Member
Just finishing up my second engine build. My first was a small wobbler and I wanted a challenge so dove into a two cylinder. Hope to make it to IC some day.
Problem: The rotary valve is one of the reasons I chose this engine build as I did not feel confident in machining gears or cams. BUT that has become the issue...the valve leaks air so that the cylinders are partially charged during the exhaust stroke. This causes too much resistance to rotation during the exhaust stroke and therefore stops the engine at BDC on each cylinder. There is a brass tube pressed into the aluminum head with ports drilled for intake and exhaust. My "valve" is a stainless rod .3745" in diameter running in a .378 ID tube. Do the math and that leaves .004 for running clearance and LEAKING. Has anyone had experience with this situation? Suggestions appreciated! Terry
