Robinson hot air engine question?
wespete66
Active Member
NW Iowa
Hi all!
I am studying the Robinson 'B' hot air engine by reading what I can find and by patent #445904 drawings. I am also 3D modeling it to help me understand it.
I've found little about the speed regulating valve found on the back end of the power cylinder. Can someone help explain the workings of this assembly, how does it work? It looks to me that air flows freely between the displacer and the power cylinders unaffected by the valve, while any pressure/compression inside the power cylinder will force the poppet shut against its seat, and any vacuum inside the cylinder will pull the poppet open against the spring to allow outside air to enter. Yes??
Does anyone have pics of the components of the speed regulating valve?
Thanks!
Wes
You adjust the valve looser so that it is drawn towards the power piston as the piston moves towards BDC which restricts the flow or tighten it so the flow is not restricted as much
It is no more than a flat head on a stem, a weak spring and an adjusting nut on the end of the stem.
Red flow of hot air draws the valve forward and closed the green gap, spring pressure alters its movement and therefore speed of engine.
It does not bleed in air, only restricts the internal flow
My scratch built 24mm bore one
    46.8 KB
