- Jan 4, 2011
- 1,414
- 383
I seem to have a problem with ring sealing. Usually after a lot of screwing around I finally get the rings to seal. I think that the problem is the finish on the side of the ring groove. The finish on the side of the groove has to be smooth, especially on the lower side of the groove. A good finish on the side of the ring is fairly easy because it can be lapped on a flat plate. The finish on the side of the groove is pretty much determined by the machined cut. Usually the groove is too narrow to get inside with any kind of file or stone to smooth it out. I have been cutting the groove with a cut off blade. I square up the blade to the chuck and plunge cut and move the tool over to get the final width. Any words of wisdom on the proper method? Tips?
