hello
realization of a 4 stroke engine rotary distribution 12 cm3 of plans after jan ridders [ame]http://www.youtube.com/watch?v=x9aiu7bOsxA&spfreload=10[/ame]
It looks great!
I'm also trying to build this engine but I can't get it run yet. I think it leaks in the valve. Did you have any problem to get it run?
good morning
no I did not have too much problem .I removed the seal segment because too much friction.
mounting grease the valve shaft because risk of seizure, also use a little oil in gasoline
