mklotz
In another thread, Rick had asked to see a video of my version of Senft's Poppin engine.
Some remarks...
The engine has aerospace-quality precision ball bearings that were rejects from gyroscopes used in fighter aircraft inertial guidance systems. They're a bit delicate for this application but so far they've held up very well.
The cylinder is aluminum with a steel facing plate where the flame is applied. This is important because, since steel is a poor conductor, it doesn't "suck" all the heat out of the hot gas before it gets inside the cylinder. OTOH, once inside and the valve shut, the aluminum quickly sucks the heat up, creating the partial vacuum that actually powers the engine. (Well, technically, it's the atmosphere pushing against the low back pressure of the partial vacuum that powers the engine.)
If you build this engine, expect to spend a bit of time fussing with the valve. My valve is a piece of thin shim stock and it needs to be formed and placed "just so" to get the engine operating. Once fixed, though, it's a reliable runner.
Preheat the cylinder with the alcohol lamp prior to attempting a run. It doesn't like a cold cylinder.
I learn something new every time I run this engine. Today I learned that it's a good idea to dry ALL the alcohol off your thumb before lighting the alcohol flame. Ouch, that smarts. Ah well, they don't call me a Klotz for nothing. (Please note that remark is not license for any of you to call me such. )
[ame]http://www.youtube.com/watch?v=eCssHXWVYm0[/ame]
Some remarks...
