- May 3, 2011
- 415
- 68
been wanting to do this for a long time now and after the little crash i had a while back and all the Z axis problems Ive been having since, best get on with it.
bit of history...... a few moons ago Muppet here broke a cardinal rule. I answered the phone when i was doing a tool change. came back to it 30mins later, saw the drill bit in the chuck and hit go. i had put the drill bit in, but hadn't re zeroed the Z height. 6mm drill hit the stock at 4500mm/min (177in/min) pushed the drill through the stock at the same time as the X travel, drill then snapped. then started to drill a hole with the chuck:wall::wall: made a bit of a mess of the head.
after the crash i could never get the head back in, the z travel wasn't smooth any more. i couldn't tram the Y axis of the head in. i could tighten up the jib to solve the problem, but then the Z stepper would stall. think the crash damaged the jib some how...............time to fit the rails.
had a look how others had done it and found one. this guy used a hand router and g clamped it to the slide of the Z and machined away the side of the column. then fitted the rail's to the side's. he then fitted the a plate to the Z slide and mounted the carriages to the plate. took the jib out and was good to go.
so i went the other way... that was to machine off the side of the dove tail and mount the rails directly onto the face of the dove tail.
first problem...... who do i know that has a big mill that will machine my mill in one hit. thx to Alan at MJ
the column was placed on the mill dove tail down. this was done so i could machine a flat at the top of the column. as the column has a slant on the back, this would mean i have a surface that is square to the dove tail for when i turn it over.
in the pic you can see the stack of parallels propping the top of the column up. packing was added till the face of the dove tail was parallel with the table. this bit doesn't have to be that spot on, as you wont be touching the face.
