S
Seanie
Guest
Hi guys, I have a Raglan Little John lathe with a reversing switch, which I'm teaching myself to use- no books, broken gears etc etc.
Got it working quite well, welded up gears & so forth- my question is re the reverse switch. If you have a chuck holding your work & put the lathe in reverse- wouldn't the chuck come undone & fall off??
I've heard of that happening, & can't really work out just why they have a reversing switch- is it just when work is held between centres without using a chuck?
