chucketn
Senior Citizen
As often happens with me, my Webster project got put on the shelf while I worked on something else. Probably shelved due to lack of material, or some other problem. That happens often.
The new threads on building the Webster spurred me to get it down, dust it off and try to continue.
When laying the Webster out in my mind. and making a few basic parts, I had the brilliant idea to use a weed eater coil and flywheel. I had several defunct weed eaters lying around, so I stripped them down and gathered some parts. I ended up with cranks, flywheels, coils, bearings, and a few pounds of aluminum for casting.
I had completed the base, bearing standards, crankshaft, cylinder, piston and con rod, and the head. I was trying to figure out how to mount the weed eater coil to be near the flywheel when I stopped.
Today, I made a simple mounting plate for the coil and set the gap between the flywheel and coil to about 20 thou.
I have attached a couple pictures of where it's at.
Am I correct in thinking with the weed eater flywheel and coil, I wont need the points and gear system? Am I full of @%#$?
Edit: Yes, I Am I full of @%#$! I just realized I need the cam shaft and lobes and gears to work the valves...
