I second what gus says. It is a very useful skill to be able to judge heat ranges for metalworking by color. I also like judging heat this way because you can also see if your heat is even throughout your workpiece. I do the high-heat metal things outdoors and find dusk is a good time to do these things.
--ShopShoe
The issue I have found is the IR units do not go above 1000F, ...
I have an IR unit that goes to 1650C (3000F). Purchased on e-bay in the past year, unfortunately the unit has no make/model or manual. Cost was not much more than the very common ones with the 1000F limit.
