SignalFailure
- Jan 1, 2008
- 366
- 3
Nearing completion of the construction phase of this little piston-valve controlled engine. Here it is held in a vice powered by a foot-pump - especially pleasing as I haven't even made a gland nut or lapped the valve face where it meets the cylinder yet (you can see gaps between the two at present!)
Outline plans here, final detailed (metric) plans to follow... http://www.homemodelenginemachinist.com/index.php?topic=4870.0
So far I'm pretty pleased with this one as I designed it from scratch and built it from whatever was to hand (steel, brass and bronze) ;D As the stroke is short it seems ok without any crosshead guide/support. The only real modification I'd make is to use a split eccentric strap (or at least re-arrange the standards) to make setting the timing easier.
[youtube=425,350]Whka7JQMEsY[/youtube]
