Thad Swarfburn III
Problem : Old Emco Compact 8 three jaw chuck, jaws bellmouthed, finances don't allow for replacement.
Proposed solution:
1: Remove jaws and clean all oil from jaws and scroll (may require full disassembly of chuck).
2: Coat scroll and jaw teeth with slow cyano or possibly even PVA glue.
3: Replace jaws and chuck 20mm dia. plastic or wood dowel in chuck, tighten.
4: Wait until glue has set.
5: Drill and bore out remaining dowel.
6: Mount toolpost grinder on cross slide and true jaws in several passes.
7: Remove chuck and heat or rap jaws to break glue bond.
8: Disassemble, clean and remount chuck.
Would this work? I'm not looking for perfect repeatability from the chuck, but anything's better than what I've got now. Judging by the condition of the rest of the lathe when I got it, the scroll won't be so good.
I'm in NZ; even the cheap and nasty import stuff is expensive down here.
Proposed solution:
