Nickademusss
- Dec 14, 2011
- 60
- 0
I thought I would share my build of the PM Research BLR 2 kit.
First thing I would like to mention is that the kit was very complete, having all the materials needed to build the tools and boiler.
The castings are top notch, very clean and easy to work with.
The plans were clear and were accompanied by easy instructions.
Its the first boiler I have built and besides all the noise putting in the rivets it was a fun build.
I used an old brass candle stick base for the funnel at the top of the stack, a PMR whistle, valve, force feed pump, and gauge. All worked well.
I ran this boiler up to 115psi (max for my airbrush compressor) for the static test (yes the boiler was filled with water per the instructions...)
It is shipped in a very small box all the parts are inside the boiler tube.
rivet tools after tempering
I used a spare 3/4" square stock piece for the rivet anvil
Steam dome soldered and all the holes drilled in the boiler tube, the steam dome top fit very well, and after it was riveted the edge was hammered down around the center piece and soldered.
Steam dome mounted on boiler, and then I began the compressing the boiler tubes, I did not make the tool from the kit stock, I used 5/8" all thread and some large joiner nuts tapered to do the job.
Everything soldered
test fitting the castings....
115psi static pressure test
finished up and painted with grill paint, I test fired the boiler on esbit, I wish I hadnt, it made a mess inside and a skim of residue over the boiler bottom.
I put a propane burner under it and love running it now!
I also added an extra water connection to the bottom of the boiler for the feed water pump connection.
The water tank on the side is a pint size paint tin, cleaned and painted with a copper tube soldered to it.
The finished boiler will run my beam engine very well, and the whistle is ear piercingly loud.
[ame]http://www.youtube.com/watch?v=iuJGj0-QYkU&list=UUXdt1NJ4cjJHLzCMzX0C2GA&index=1&feature=plcp[/ame]
This is the type of burner I used, only slightly longer, a simple hollow block with holes drilled every 5/16" and a gas jet at one end...
I had so much fun building this boiler I think I would like to build the vertical boiler BLR1.
Everything soldered
