- Dec 9, 2015
- 327
- 350
Hi all
I've almost completed my v4 engine and attempted a start. While it does fire, it isn't self sustaining and I've attributed this to a low compression ratio.
I'm not familiar with what my compression ratio is as I don't know what capacity I've machined the chamber in the heads, but I did make the piston to head clearance at 2mm which I'm thinking is too much. I don't run a head gasket. When turning the engine by hand, there aren't any leaks and it does feel compression is there, but not enough.
My question is, what is the largest piston to head clearance someone has had success with a running engine, and what clearance should I be aiming for?
Thanks all
Andy
Thanks all
Andy
