Hi Bill,
Re: your post "I wonder if I could epoxy the cylinder liner to the cylinder case with good results instead of silver braze that the print calls for?" - prompts me to ask "what shear strength epoxy?" - and the same goes for the silver solder. I suggest you check the shear strength of the silver solder and epoxy at the max temperature expected of the joint... (Hot enough to boil water = 100deg.C, Hot enough to smoke-off oil = 200deg.C).: tensile strength of silver braze alloys is 40,000-70,000 psi. Epoxy Physical Properties ; Tensile Strength (PSI), 7,846, 7,320 ; = 1/6th that of silver brazing at room temperature.
e.g.
Master Bond EP33 High Temperature and Thermal Cycling Resistant Epoxy:
Master Bond Polymer Adhesive EP33 is a unique room temperature curing two component epoxy adhesive for high temperature bonding applications. It is formulated to cure at room temperature or more rapidly at elevated temperatures. Master Bond Polymer Adhesive EP33 produces high strength bonds whose strength is maintained even after long exposures to temperatures in the 400-450°F range. (I.E. around 200deg.C).
If only 100C, I guess epoxy will suffice, but if >200C then you probably need the silver solder. Also consider forces involved... as you don't want a weaker joint to move/creep during service, and either wear badly or destroy the engine?
I have bronze brazed and re-bored a cast-iron engine cylinder that ran successfully afterwards, but would not expect an "organic material" to withstand the stresses and temperatures involved, even though epoxies have good strength at room temperature. All glues deteriorate their strength with age, epoxies and polyurethanes included. It is just that they age differently with temperature and stress, so seldom last the lifetime of a metal repair.
As to "loctite" and other anaerobic sealants: they are good for maybe just over 300C sort of limit, if you select a high temperature grade. Probably why Colin had success with this but not epoxy?
SONLOK® High-Temperature Resistance Adhesives are specifically formulated for applications that are continuously operating in high temperatures, even up to 340°C without degradation.
