vederstein
Must do dumb things....
- Feb 26, 2011
- 927
- 760
"Soon" I will be building the Myers Heinrici stirling engine casting kit I received for Christmas. I'm a bit intimidated by the piston on this engine. It's 1.500 diameter and the bore is about 4 inches.
http://www.myersengines.com/engines/Heinrici.htm
I've built a couple of small stirling engines in the past and most posts on this forum give advice on the smaller engines.
The plans call for a cast iron piston .0005 to .001 under the cast iron bore. I'm concerned I won't be able to control the cylinder and it may taper during machining or when heated up.
On a larger stirling engines like this, do piston rings make sense? If so, any suggestions (material, size, source of supply)? What about the displacer rod clearances, which goes directly through the center of the piston?
If anyone has built this engine, could you please let me in on your experiences?
Thanks,
Thanks,
