Hello guys,
First of all, excuse me if my english is a little bad!
The last couple of days I have been reading about how to make piston rings, and I have now decided to make some on my own.
I took a part an old nitro engine (OS MAX 60 H blackhead) some years ago because of bad compression. I remember that I took the piston ring of, but now I can't find it..
I have red about different methods on the forum which describes the
thickness, OD and gap. But what I can't find is the ID (boor) of the ring. I do belive that there should be some "back clearance" so the gasses can force the ring outwards.
What should that clearance be? (mm/inch)
Some info about the piston and sleeve.
Sleeve ID (bore) = 24mm
Piston is OD = 23.95mm (ish)
The ring slot diameter is 21.8mm
For the non-metric guys :
Sleeve ID (bore) = 0.944''
Piston is OD = 0.942'' (ish)
The ring slot diameter is 0.858''
Andy
Andy
