Picking a rotary table
bradbyname
Active Member
I have a Sieg X2 mini mill, and im looking for a RT so i can mill a radius which i will need to do for a variation of the stirling engine.
Does anyone own one of these?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290537063291&ssPageName=STRK:MEWAX:IT
I wouldn't mind some feedback on this before i make my purchase :) If you have another one you would recommend oppose to this one, please by all means share it with me I'm all ears.. well... eyes i guess ;D Its just this one jumped out to me as it comes with the three jaw chuck and a tailstock
Hi There
irrespective of quality of the product (on which I cannot comment) a 6 inch RT is FAR too big for the X2.
I use a 4 inch table with a 75mm Proxxon chuck and find that this is too large for the standard X2 table, limiting the Z-axis to the extent that it makes the entire set-up impractical.
suggest that you have a look at RDG Tools product number 847433 (3 inch RT) as a pratical size for the X2. there are any number of chucks on the market that would fit this table. However I would recommend against a conventional chuck and reconmmend that you look at the Taig, Sherline or Proxxon chucks as a better size comparable with the X2.
have fun
Bernard
The Model Works Australia
I use a 4" Vertex RT on my X2 mill, with 3" and 4" chucks with no problem. Looks like a good deal pricewise with chuck and tailstock. But, I agree, 6" is probably way to big for an X2 mill.
Chuck in E. TN
Hi, I too use a 4" Vertex RT with my X2 and find it to be about the right size. It's very well made and comes from Taiwan. I'd think a 6" would be too big for the X2.
LMS has some good looking 4" RTs also.
I first bought a 3" RT identical to the one below (made in India) and it was a total waste of money. Way too much run out, poorly designed locking mechanism and bad build quality.
Good job i posted by the sounds of it. that could have been a costly mistake.
Thanks for the suggestions, i will have a look at the 4" makes you have been so kind to highlight
If you were thinking of going to CNC at any time or just a division master then the ones ARC sell are quite receptive to having stepper motors fitted.
J
Hello,
I am also interested in purchasing a RT. What are the opinions for the Shop Fox 4" RT?
http://cgi.ebay.com/400222967801?ru=http%3A%2F%2Fshop.ebay.com%3A80%2Fi.html%3F_from%3DR40%26_trksid%3Dm570.l1313%26_nkw%3D400222967801%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
* Horizontal or Vertical Use
* 4-5/16" T-Slots
* 1:72 Ratio or 5° Per Revolution
* Vernier Scale Reads to 10 Seconds
* 3 Dividing Plates
* Sector Arms
* Indexing Pin/Handle
* MT #1 Spindle Bore
* Coolant Trough
* 10mm Locating Key
OR
http://www.littlemachineshop.com/products/product_view.php?ProductID=2183&category=
LMS #2183
4" (100 mm) diameter
Use in horizontal or vertical position
Worm ratio is 72 to 1
10 second rotational accuracy
2 Morse taper center hole
What are the advantages or disadvantages of the different worm ratios?
Thanks for you help
bazzz said:
Hello,
* 4-5/16" T-Slots
* 3 Dividing Plates
* Sector Arms
* Coolant Trough
* 10mm Locating Key
The same one is sold by Grizzly for $161. I bought it several years ago. There was a little bit of scraping noise so I took it apart (easy to do) cleaned out the existing grease which had some sort of grit in it from manufacturing and now it works perfectly. It's not as pretty as some but for that price with index plates, it's hard to beat.
http://www.grizzly.com/products/4-Rotary-Table-w-Indexing/H5940
-Trout
Thanks Trout, I just placed an order with Grizzly. Now I will just have how to learn to use it.
