This is a question that has hung in the back of my mind all my life. When I was a boy in the 1950's, steam trains used to come into the junction near where I lived. Although warned by my parents to stay away from the train yards, my curiosity about all things mechanical made that impossible. The big old steam engines had two cylinders, one on each side of the train, and when they shut the engines off, they would coast to a stop. The two cylinders were out of phase by 180 degrees, so that when one piston was at top dead center the piston on the other side of the train was at bottom dead center. What happened if they stopped in that position??? You can't flick the flywheel or push start a multi ton locomotive to get it moving, and in my experience when a piston stops at top or bottom dead center, no amount of steam is going to make things move.---What did they do to get the engines rolling over????????
