oscillating steam engines
steamy
New Member
hi
does anyone know of any plans or kits for a wobbler with 1"or 1.5" bore.
is there any info on how to work out bore stroke ratio and how to mark out and drill the ports in
the correct place
many thanks steve
hi deverett
if you enlarge existing plans do all the relationships stay the same bore stroke ports etc
steve
Yes just scale all lengths by the same amount, angles do not change.
If you want a kit then Myers do a vertical with 1" bore
http://www.myersengines.com/engines/creators_vertical.htm
I just made this one from some photos of an old model and a bit of googling for the port positions. 24mm bor eand all barstock except the flywheels
