Plug Driver
5 plug at 3A need a 1.5V(adjustable) 15A regulator from a 12V source.
I was a power supply designer for 40 years and this is no different than a typical PC supply. The only issue is that I do not like home grown electronic project, I do not have all the parts and equipment I am accustomed to have working professionally.
If you plan to always run the engine on a display stand close to a 120 VAC receptacle, An easy glow-plug supply can easily be made from a small power supply transformer ( 50-100VA) by cutting off the secondary winding ( usually on the outside) and making a new secondary from # 16 or 14 insulated wire. There should be enough room to put in enough turns to give 1.5V @ 15 A. Simple and bulletproof. Put in a plastic or wooden box with a primary switch and you are done.
WOB
