- Apr 7, 2009
- 21
- 1
Hi everyone. This is my first post and my first build, I hope I get both right. I bought a lathe a few years ago, but employed it largely making pieces for my other main hobby - model boats. I made several cannons, drive couplings, bushes etc., but nothing that actually "worked". I have been "lurking"on this site for some time now, but the postings for Cracker; Nina; Idris have inspired me to try and make something that really does something. I have been working on a scaled up (45mm) Cracker (and the house) for about 4 weeks and have become so absorbed that I even bought a milling machine last week - what a wonderful machine! I wish I'd had it at the start, my side frames would have been much better (I'm not very good at filing). The wheels are made from some sort of duralumin type alloy that was lying around my shed. It's has a sort of greasy feel when being turned and produces long bits of curly swarf. The wheel bosses are large because I was worried that the soft alloy would strip if I screwed the wheels to the axles too tightly. I have since acquired a chunk of 'meehanite'? and have turned one wheel with a smaller boss as an exercise
Anyway, a month and a large rubble sack of swarf later I have reached the position shown in the photographs. Next I have to make the cylinder and piston, an exciting but slightly daunting prospect.
Questions:
(i) If I use a template to drill the exhaust and inlet holes on the standard, what angle before or after TDC should I go for. Common sense seems to suggest that the steam should be admitted almost immediately after TDC and the exhaust just after the bottom of the piston stroke, but could last for the whole upward stroke (I don't need reverse on this) - but common sense has let me down before.
(ii) I was trying to apply a nice surface finish on the standard with a fly cutter, but ended up with something that resembled a ploughed field -the brass seemed almost melted. I wasn't taking a deep cut, was the speed too high? the fly cutter is new, so should be sharp. I managed to redeem the piece with some judicious sanding, but it doesn't bode well for the piston.
I attach some pictures of the progress to date.
Questions:
