- Jul 16, 2007
- 3,027
- 1,118
Gentlemen,
I'm not quite sure if this is the right category to start this thread in but it's of general interest so here goes.
Having had discussions on this forum about the new digital readout scales that are available from Grizzly and others and the very reasonable cost associated with them I purchased one from a supplier on Amazon.com. I needed one about 32 inches for my 11" Logan lathe so I opted for the 36 incher. It came the other day and when I unpacked it I found probably the biggest reason for the low cost, the beam is made out of aluminum. All of the other scale units of this type that are available from multiple sources have stainless beams similar to the way the digital calipers are made.
The beam seems to have some type of anodizing applied to it but it's still quite soft. Any incidental bump will give it a little ding on the surface. This is not a problem because it will file right off.
I have mine hooked up and working the only problem is that it's virtually impossible to tram or align, at least with this length. It's so flexible that trying to indicate it is virtually impossible. With the shorter lengths available I'm sure this is not that big a problem.
So if anyone is contemplating purchasing one of these new readouts just be aware of the situation. It might be better to go with one of the stainless types for the strength and wear. I have one of the stainless setups on my Enco mill for each axis and it hasn't given me a minutes trouble.
George
George
