learninturnin
rusto
- Oct 29, 2015
- 7
- 3
Hi everyone. This is my first post. I have been trolling the forums for a few months, just absorbing, learning, and checking out everyone's builds. I have been hesitant to post as everyone's engines are so impressive and mine is well...not working for one.
I am very new to machining. I have wanted to get into it for a while, but I have just pulled the trigger in the past few months. Lots to learn. In my spare time I have managed to cobble together this little engine. Unfortunately, it does not run and I was hoping some folks here might have an idea or two as to why. I have my own theories, but I was hoping some more experienced people could weigh in with a few tips.
1) there is some wiggle room between the piston and the cylinder. As in if I hold the cylinder and turn the crank shaft/flywheel, the crank/piston can rotate maybe 10 degrees individually of the cylinder. Is this causing the piston head to catch? Should the piston head be tighter inside the cylinder? There does seem to be a little grab or resistance at certain points...
You can actually see in the front image that the piston rod and the cylinder are not perfectly parallel to each other. It really is a very small amount though....
2) Could it be that the crank shaft or the pin holding the cylinder is not perfectly at straight angles and therefore adding some wobble/friction between the cylinder and the piston?
3) There is also some room between the cylinder pin and the hole guiding it through the frame. Not a lot but enough so it is a little loose. Problematic?
It seems as though if I spin the flywheel it should be free enough to spin around a few times - its does not. I'm not sure if this means anything or not.
Thanks so much for any insight. I look forward to joining the forums and a future of building stuff out of metal.
and a video if you are so inclined. Password: engine
[ame]https://vimeo.com/144004374[/ame]
