Feliks
- May 6, 2010
- 144
- 48
New Wind Engine :
Here the newest model of the wind my car .. Only cosmetic changes on the outside ..
But inside the revolution ..
I present two screenshots of the simulator NASA airfoil and it is clear that at different angle of attack with a symmetrical profile, receive different values ??of lift .. From negative to positive .. or 160 KG positive, or 160 kg (320 lbs) negative (downward pushing sash) when changing the angle of attack of 30 degrees .. and dimensions of the wings 2, 5 meters square at a speed of 100 km / h (60 miles)
Well, this wing of their forces can drive the crankshaft directly ..
Here, the animation .. The angle of attack of the wing can change either electrically or mechanically (cam) There is no need for this high energy ..
https://youtu.be/evC5y0wgOVM
[ame]https://www.youtube.com/watch?v=evC5y0wgOVM&feature=youtu.be[/ame]
Well needless to say that such a system also can work at creating their own wind ... ..
I had to publish it on Santa Claus, but that the climate summit a little hurried me .. Because after what happened there in May too tired and negotiate, as you no longer need .. maybe someone out there will send a telegram?
Andrew
Andrew
