New V4 Steam engine Model
galglg
Active Member
Overall dimensions: (mm)
Bore : 14mm
Stroke : 16mm
Each cylinder Capacity: 3ml
Planetary Gear ratio: 4:1
Flywheel diameter : 37mm
Output shaft : 5.5mm
Other Output shaft :4.5mm
O.A. Length : 150mm
O.A. Width : 110Mmm
O.A. Height : 90mm
Net weight : 950G
After testing, when the pressure of 4 kg, it can reach speeds above 1200 rpm.
Video address:
http://player.youku.com/player.php/sid/XNTgzMjg1Nzky/v.swf
That is just about the most amazing thing I've seen in ages! Spectacular work!
cheers, Ian
Beautiful engine, and nicer construction. Bravo!
For a similar look, made from bar-stock, check: Rudy Kouhoupt's ---- V-4 Steam Engine.
Which came first? Both are great!
Frank
