Correct, I was given the engine by Enjomor/StirlingKit. I have then homemade the parts around it.I like small engines, all small engines, no matter how simple, and I don't care where and by whom.....
But, This is the forum " Home model engine "
If you want to advertise : Please consult the admin !
this design is not helped by the top outlet being angled down -
Thanks, I will drop the lower point on the tank, then raise it further on the stand and increase the upper point. That should give a longer upper pipe run.No problem with a bit angled outled pipe from engine, its length of the hose from the top of the angled pipe on the engine to the top of the pipe on the cooland barrel/radiator must be long enough to keep coolant circulating.
Glue-Itcom,.. Here is my gas engine with thermosiphon cooling
