- Dec 2, 2008
- 971
- 9
Hi Y'all
I'm back. The shop is decommissioned for a while longer but I have been thinking about a new project. The design has been kicking around in my head while I was away but since the battery on my laptop battery died early in the cruise, I was only able to design in my head, with a few sketches to keep it real.
Before I left, I had been knocking a few ideas around. The "Pull My Finger Engine" http://www.homemodelenginemachinist.com/index.php?topic=4291.0 was a test of the Z-Axis mechanism and will be the basis of this design. I had been thinking of building a 3 cylinder Axial engine similar to the "Weeble" engine http://www.homemodelenginemachinist.com/index.php?topic=3540.0 but I have now changed that thought. The new engine will be a four cylinder design. It could also be considered a two cylinder, double acting design since there will be two cylinders with two double headed pistons. The cylinders will lay parallel to the shaft (Axial) and will operate the spider arms through a four motion bushing in the center of each piston.
The design of this four motion bushing is the second major design problem critical to this engine ( after the z-axis bearing ) and has not yet been tested but I believe that I have the major points covered. The design is done, the execution will follow.
The third critical design element is the valve mechanism. Previous experience with rotary valves has been less than ideal. They do not seal well and they make it difficult to incorporate ball bearings. I looked at Elmer's 3-cyl radial and the valve seemed to solve these problems but I didn't like the small pin that drives the valve disk and I also didn't like the fact that this valve makes it impossible to have a double ended output shaft. I borrowed the concept and modified it fix what I thought were shortcomings. I've got the design worked out but it hasn't been built yet.
Most of the details have been worked out using Alibre' since I got back and have the use of my laptop. I am using the free version which limits assemblies to five parts so I can't post a fully assembled model. I'm not sure that I can get the partial assembly PDF to post but here's trying.
I'll post some progress pics when I make some progress but for now feel free to comment.
Jerry
View attachment Spider Plates and Cyls.pdf
Jerry
