Today was my second day of break-in on a compression ignition engine I machined and assembled. Its the ML Midge engine. I noticed some exhaust gunge coming out where the compression screw enters the cylinder head (see the two photos). I was not expecting that. It must mean there is some exhaust leaking past the contra-piston. Is this normal, or do I need to go make another contra-piston? I did have one good several-minute long run where the RPM seemed correct, but other times the engine is just chugging along (see video too). Another run and the engine was running slow but as the fuel was fully consumed it seemed to run faster - so that run was several minutes long.
I feel like I have the fuel recipe down.
There was a prior run where I felt like I possibly turned the compression screw too far and the piston was hitting or close to hitting the contra-piston. Is that a big deal?
