Hi all, I am after a bit of advice, I am pretty sure I know what the issue is but wanted to ask in any case.
I bought a Davies Charlton Sabre diesel on Ebay that was said to be in excellent condition, turned out to be "not as described".
The engine is free to turn but the piston gets stuck in bore just after it passes exhaust port (travelling up). It seems imposible to turn over, but I know better than to force it, I do not want to damage rod or even break crank pin off which can happen. On inspection the cylinder head was loose (so definately been tampered with) and the engine shows signs of wear on all parts eccept the piston and conrod. I believe that the bore on these engines is tapered and someone has fitted a new piston which is ever so slightly to large and needs lapping to fit bore.
What do you think?
I have been building and flying models for 40 or so years, so am experienced with these ehgines. Have worked on many car and bike engines and have a good mechanical knowledge. I have also now built a handful of live steam engines, so know enough about fitting pistons. I also once made a piston for a Nova Rossi car engine. Attached is a picture of my last project, designed and scratch built by me, to give you an idea of my ability and knowlegde.
TIA
What do you think?
TIA
