Recently picked up a used X2 with very little use for a good price. After years of attempting to mill on my '37 Craftsman 12" with a milling attachment I got a mill.
Started immediately to come up with ideas. First thing was a belt drive using steel pulleys instead of aluminum like most. I think the added weight of steel makes for smoother milling.
Next was a spring loaded spindle lock.
Then came a column brace. Used 1/2" 6061 aluminum plate with 23 M6 bolts holding it together. Plus original nut which now uses a 1/4" thick washer. Then 4 more bolts threw base and table. The back of the column is plated up to the electrical box using 6" wide plate. Bolted together with M6 cap screws that can be seen plus more under the reinforcement plates that are counter sunk. I cut a hole to give me access to the LMS gas lift as can be seen in the back. Then the mill is bolted to a 200lb table.
Then a LMS gas shock which works great.
Well it didn't take long to get tired of cranking the table. After looking at dozens of types of drives from simple and cheap to expensive ones like the LMS model. I just didn't think I would need all those electrical boxes, switches, potentiometers etc.
I just used a B&D drill motor and clutch and the original trigger/reverse switch. The chuck just pops off and this went on the shelf as was not needed. This gives me variable speed and forward and reverse in one switch. Stops before crashing just by the clutch. The drive shaft and disconnect was so simple compared to the complicated ones I have seen. Took no time to make.
So far I have a lightly used mill as owner also had in his home garage a full size mill, shaper, lathe and much more. This mill and a small lathe were his starter models. Total investment so far with all materials and mill is $400.00.
So far everything works perfect including my drive system.
