K
Kermit
Guest
Burning through those D cell batteries in a most UN-green manner. The youngest son loves his remote control Robotic Arm. The wifes i$$ue was quite clear to see. She even helpfully suggested rechargeable batteries, and was still willing even after she priced them in Dcell sizes. I reminded her of our past experiments in using rechargeables, and after a short time spent in introspection, she "ok'd" my requests for a spending spree at www.alliedelec.com
A project box, an AC power cord socket(panel mount), two TDK-Lambda 25W 3.3V 6A switching power supplies, assorted colors of hook up wire, and a few screws, nuts and washers, and crimp on terminals for the output strip connectors.
Some old skool cable lacing, mostly just because.
setting power supply to the new output voltage of 3.0 volts(adj from 2.8 to 3.6)
3 pin mini-DIN male and female, selected for low profile of female panel mount solder pins. The switch was difficult to select, since all of them touched the batterys below, or were to large for the DIN plug to fit beside it. Finally found one with suitably small closed brass lugs. (DPDT on-on)
and finally a photo of the entire robot arm which the supply will power.
And the whole project came in under $40, thanks to some found parts in the old junk pile. (connectors and wire etc.) That just about matches what we've paid for the young ones batteries so far.
Any suggestions or comments most welcome,
Kermit
Kermit
