BaronJ
Grumpy Old Git.
Hi Guys,
Since my Chinese mill does not have a motorised table traverse and I don,t fancy paying the rather exorbitant prices that are wanted for them I have looked at a lot of designs on the web and decided to have a go at building one.
Also its a pain, in more ways than one, standing there winding the table back and forth.
So I thought that I would see if I could design and build one from scratch. With this in mind I decided to have a trawl around my local scrapyards for something suitable to use and came across a car windscreen wiper motor.
I found this one from a wrecked Nissan Micra. Being lazy, I grabbed this one because it was very easy to get it off the chassis bulkhead. Four hex head bolts and it fell out. The power connections were a very convenient plug and socket attached to the back of the gearbox.
At this point I didn't know what condition it was in, only that it was quite clean with only a little rust on the motor case where the paint had flaked off.
When I chose it I didn't realise that it was a two speed motor, but on testing it, it soon became obvious. It also had wipe home switch built into the gearbox which confused me at first.
Anyway it runs quietly in either direction at both speed settings. Though I'm informed that these wiper motors don't like being run backwards so that is something to remember.
The photographs show the motor after I had removed the wiring and connections from the back of the gearbox. Though you can't see it, I drilled out the rivets holding the gearbox together and stripped it down. The grease inside was more like wax than grease. So I cleaned it all out and re-lubricated the shaft, gearwheel and pinion. The gear shaft runs in a phosphor bronze sleeve.
I threaded the holes where I drilled out the rivets 4BA and made a new gasket to go between the two halves of the case. The original gasket was a line of what looked like hot melt glue. I had to double the gasket material thickness so that the gearbox cover plate didn't bind the gearwheel. I used 4BA countersunk head screws to fasten the coverplate.
Part of the reason for stripping the gearbox down was so that I could get at the switch mechanism inside and remove it. It also removed half of the wires that went into the harness socket that was mounted on there. So now there are only three wires to worry about. Common, high speed and low speed.
One of the photographs shows the plate that the motor was secured to the car bulkhead with. The nut on the end of the shaft is M8 and the splines secured the wiper driving arm.
