- Dec 28, 2008
- 1,731
- 9
Here's some pictures of my latest engine. The basis for this build was Elmer's chapter 11 radial. I made quite a few changes from the original plans. Some of the basic changes included changing the bolt circle to accommodate round cylinders and cylinder heads. This exposed the four mounting studs and required the use of external porting to the cylinder heads. The piston size was reduced to .500'' X .500'' which required the cylinder skirt to be opened up a bit for piston rod clearance. Due to the larger cylinder heads it was necessary to raise the crank case block to 1'' for clearance, this also allowed the use of a larger base. To match the raised height of the crank case the bearing block was height was raised by 5/8''. Since I raised the height of the bearing block and crank case, I choose to use a larger flywheel to offset the larger sized cylinder heads.
I took eleven days to build this engine from start to finish. I did the final assembly and break in yesterday evening despite being ill with the flu for the past four days. After assembly I noticed the bearings were binding slightly and I had to make several adjustments using the four screws that hold the bearing block and the crank block. After about 10 minutes of running the engine smoothed out nicely and it feels very smooth when spun by hand.The engine is very quit and runs great. It will run dead slow on 1 lb or less of air, and on 5 lbs its plenty fast!
Completing this engine was a very satisfying experience. Words can not describe the feeling I get seeing one of my builds run for the first time. I hope you enjoy the photos.
MB
Front view showing my unusual flywheel.
I used phosphor bronze bushings on the bearing block and crank case.
The intake is located on the right side of the valve housing.
I drilled a passage for oil drainage and added a short spigot capped with a Teflon sealed 4-40 screw to act as a drain plug.
I went with a slightly larger vent plug tapped for and threaded 5/16''-40. The added muffler does actually work and reduces exhaust sound considerably although it is not necessary.
Here is a link to photos that can be viewed original size: http://groups.yahoo.com/group/Elmer...riginal&mode=tn&order=ordinal&start=1&dir=asc
MB
