Hi Guys,
It has been awhile (December I think) since posting but I have been lurking here almost every day. I hesitate to post because, as I have mentioned in the past, I am really bad at documenting as I go and I know as soon as I post a picture everyone will want more and I simply dont have more to share. I figure a little is better than nothing so here goes.
My model is a quarter scale replica of a 100 HP flathead Ford V8. I have a friend in the restoration business and he has been gracious enough to lend me parts as I needed them to scale down. There is also a lot of information on the internet since this particular engine is said to be the most hot roded of any. Everything is from billet with no help from CNC. I started with the block. I did a 3D drawing in Alibre Design.
Then I started whittling and ended up with this.
I then did the Crank, Cam, valves and lifters. Sorry I dont have a picture but here you can see the cam and crank in the block.
I decided to do custom heads as was done back in the day. Sharp made the most desirable at the time so I borrowed one from my friend and set out to duplicate it. The only way I could figure to get the text in the head was with EDM (which I had no experience in) so I started asking around and found a guy close to where I worked and took one of my completed engines over to his shop and ran it for him. That is all it took and he loaned me his knowledge and machine. People are so incredible!!
Once again with the intake I went with the hot rod approach.
The carbs are Perry for model airplanes. The next items were the Distributor and Water pumps.
At this point I have completed the pan and starter. Sorry no photos yet. I finished up the rods last weekend and plan to work on the pistons and rings next. I will try to get some pictures of the individual part for you soon.
Best regards,
Roger
Best regards,
Roger
