Hello all,
I am pretty new to this board and find it a really interesting and useful forum.
I have been working on my hot air engine very sporadically since the new year, well, before that if you include the design stage. I have just finished the last parts and assembled the engine. Although there are a few mistakes, the engine has gone together and seems to turn over quite nicely. The parts (I think!) were all quite a good fit and I am quite proud of my achievement as it involved lots of new techniques for me.
However, tonight I am quite disappointed as I tried to run the engine for the first time ... not only will it not run with a tea light candle (as I designed it for), but it won't even run with a butane pen torch on the hot cap with it glowing red!
I think I know the problems with it but would be interested to hear anybody else's views also! I think there are a few things:
1. The ratio of swept volumes between the displacer and power piston isn't large enough, so not a large enough volume of air is being heated and displaced. I designed it as 1:1 i.e. power and displacer pistons are about the same diameter, but with hindsight that was silly, I think that would require a massive temperature differential to get it to run, especially on this small scale.
2. The cooling on the cold end of the displacer cylinder is not good enough.
3. There is too much dead space in the tubing between the displacer cylinder and power cylinder, I've not worked this out but now I think about it, it's probably quite large compared with the actual cylinder volumes which can't be good. At the time I remember thinking I didn't want to drill the tubing too small as I thought it might choke the engine somewhat.
4. Friction - I think it's ok, it's got ball bearings for mains and big ends and seems to turn over quite well, however, I have nothing to compare against. It spins over for 4 - 5 secs with the tube disconnected between cylinders.
Does anyone have any thoughts on the above?!
My first thought is to try making a small bore copper tube as originally intended to connect cylinders and reduce dead space, don't think this will solve it though.
Then I was thinking of a larger displacer cylinder, piston, hot cap etc. bigger diameter giving a greater volume of air to heat and displace. I think at the time I designed it to suit the only stainless steel I had for the hot cap ... silly decision!
Either that or just put it down to experience and design and build another one! I changed my lathe for a much better one and sold my milling machine about half way through this project. I am now on the look out for a decent vertical miller so it would be nice to start something from scratch on this far superior equipment. Maybe this time I should use a recognised design, however, I am semi confindent that I could design one of these and get it to work as it did have some small glimmer of life, it nearly picked up when the hot cap was glowing cherry red, but obviously this is a long way from what I envisaged originally!
How people sucessfully get the LTD Stirling Engines to work is now beyond me ... hats off to you guys!
Nick
Nick
