My first engine
TuxMan
Tuxedo NY
Hi all
I am new here and would like to show the engine that I recently completed.
I adapted a design that I found on the web and here is the results of my efforts.
I was very pleased when this engine ran on my first attempt. It will run down to a few psi (don't know exactly since my readings are iffy less than 10 psi). I know the finish is not up to the very high standards I see here. I will work on that for my next build.
Thanks for looking
Eric
Welcome Eric and thanks for posting the pics. Looks very nicely done for a first build !! Any chance you can post the pics a bit larger so more of the details show.
Bill
Bill -- Thanks for looking.
Lets see if this is any better for the pictures
Eric
Good job Eric Thm:
That's a big one ;D
Regards, Arnold
Very tidy job, a credit to you.
Very nicely done. Congratulations.
You're going to get along just fine here.
Eric,
Welcome aboard. wEc1
You have machined a fine engine.
Thanks for sharing.
SAM
Very nice engine Eric. I like your design details. Thanks for sharing and welcome to this forum.
Phil
Eric,
Nice one. :bow:
Best Regards
I wouldn't be to concerned about the finish on your engine. It looks quite nice to me, no tool marks, nice square corners and if it runs well I'm sure it has the needed accuracy. Don't worry about comparing your 'first' engine to some of the things you see on this forum. I and others have been doing this for many years so you learn with experience.
gbritnell
Thanks for the larger pics Eric. That helps a lot and shows off your nice work even better !!
Bill
Hi Eric
nice clean engine... :bow: :bow: :bow:
Best regards
paolo
Bill, Arnold, Tel, Marv, Sam, Phil, Jack, Bob, gbritnell, Paolo, Jeff
Thanks for the kind words and warm welcome.
Arnold, this engine is larger than many of the engines here. I made it a little larger figuring that I did not want to work on a smaller scale for my first build. For what it is worth here are a few key dimensions and features.
Bore 1.000"
Stroke 1.200"
Cylinder block 2.00" high
Crank shaft turned from a single piece of steel
Ball barrings for the crank shaft support
I have drawings that I worked from that could be cleaned up to reflect as built and shared if anyone is interested.
Now I must decide what I want to build next.
Thanks again
Eric
Thanks for the extra info Eric :)
That may have been a wise choice, especially as you seemed to make a couple of modifications. There are some other members on here who likes to do larger engines as well - they might be interested in your plans. I'm too, but getting the larger materials for me is a bit difficult and expensive.
Good luck on choosing your next one ;D
Regards, Arnold
I think it looks great, Eric. Crisp edges and no rounded over corners. Very clean.
Just because it doesn't look like a Mr. T starter kit doesn't mean it's not well finished!
An attractive design, too.
Do you have a way to make videos? I'll bet a lot of us here would like to see and hear
it running!
Excellent first effort!
Dean
Thanks again to all for the kind words on my first engine.
Dean, per your request I am including a short video of the engine in operation
Enjoy
[youtube=425,350]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/U9Ff0IMyef4&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/U9Ff0IMyef4&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Eric
