The problem with some of the kits out there is that they tend to be approximations of the real engine.
The Galloway kits I have seen have a cylinder that bolts onto the frame, but that is not how the original Galloways (at least the 7.5 hp my dad had) were made (the frame and cylinder were a one-piece construction).
And so if I am going to go to the trouble of drawing an engine, I want it to be just like the original, not an approximation.
With the advent of 3D modeling, and 3D printing, there is no need to approximate anything, in my opinion.
Why change from the original design when modern design tools are available?
And I don't necessarily like to adhere to fixed scales either, and if I built an Olds, I would probably make one with a 10" diameter flywheel, so I guess that would be a 62.5% scale?
One of my pet peeves (on of many according to my wife) is the approximation of the spokes in the flywheels of a lot of kits.
Original engine flywheel spokes generally were ellipsoidal in section, with a taper in both axis that looks visually correct.
The flywheel spoke design is often the first thing that seems to be thrown under the bus when people kit an original engine.
That being said, I think Jason is right, but I would still prefer the old Briesch hand made drawings, just for nostalgia/originality.
I can work out the geometry from the photos and videos alone, but a set of 1/2 size drawings would definitely speed up the process.
I am not sure about trying to use 1/4 scale drawings, but I did get an email back from MiniSteam, and the 1/4 scale drawings are available.
I don't see 1/2 scale Olds castings available anywhere.
A set of 1/4 Ministeam Olds castings sold last night on ebay for $420.00 with $16.00 shipping, and I am not sure if that was a complete kit, but it did have two frames (photo below).
I would hate to think of what a 1/2 size Olds kit would go for.
I am not aware of anyone offering a 1/2 sized Olds kit.
Edit:
My appologies for totally hijacking this thread.
Edit2:
The parting line is vertical, along the long axis of the engine, along the centerline.
The water hopper front/back is bowed out with draft angle.
