rake60
- Jul 8, 2007
- 4,756
- 125
We have a couple threads running discussing the two tapers in the mini mill spindle.
I didn't want to highjack one with my personal opinions so I'll do that here.
I like Grizzly machines because their customer support exists if there is a problem.
I didn't buy a Grizzly mini mill because of the MT-3 spindle.
Instead I to the opposite extream and bought a Cummins mill from one of their
traveling truckload sales. If you have a problem with a Cummins machine you will
often find that YOU have a problem. I bought it there for the lower cost and
the fact that it had the R8 spindle taper.
The MT taper has been around for a long time. It was invented by Stephen Morse sometime
between the years 1864 and 1868. It's original intended use was to drive his new twist
drills. It still does that very well! In a drill application there is normally a slot in the spindle
that a drift is driven into to release the tool. In the mini mill the MT-3 tools are retained
with a drawbar. The tools are released by loosening the drawbar and rapping it with a brass
hammer. Given the long contact surface of the taper they often do not release easily.
Every rap is a lateral impact on the spindle bearing. Those are ball bearings that don't take
that kindly. You can find collet holders and collets for the MT-3, but very few tools.
The R8 isn't nearly that old. It was developed by Bridgeport Machines Inc. sometime after 1938.
It become an industry standard very quickly. The small X2 has a 17MM hex on the draw bar,
but the threaded end is the Bridgeport standard 7/16-20 imperial.
The steeper contact angle of the R8 allows for a much easier release when the draw bar is rapped
with a lighter hammer.
(OK I usually rap it with the side on the 17MM wrench I'd used to loosen it, but that's not good!)
Tool and collets are plentiful and inexpensive. I would much rather use a one piece R8 cutter
than a cutter held in a collet. They are easy to find.
Rick
Rick
