- Jun 24, 2010
- 2,425
- 959
On the head of my radial engine, the intake & exhaust tube flared lips are retained against the internal ledge of a counterbore by a threaded nut. The threads are 7/16-24 TPI. The bottoming tap I'm using has the typical couple of threads chamfered off so my full threads end about 0.1" from the end of the tap, maybe a bit more. I would really like to gain back as much of this un-tapped distance as I can.
I already modified the heads a bit larger in diameter so I can get more thread engagement. I might be able to deepen the counterbore face a smidge more, but then it starts getting close to other holes & features. The sketch doesnt show a .050" washer but I've already got that factored in.
Is it viable to modify another bottoming tap, grind the chamfer off nearly completely & chase this thread further down to the bottom? Somewhere I thought I read this doesn't work very well, but I cant recall if true or why. Very weak tap edge that will likely break?
Alternatively I could turn down the male threads on the nut so it penetrates further in. I just have very few threads to engage the head as it is. Plus the nut enters the head at an angle so its partial hole contact & thread engagement is further reduced by cooling fin grooves.
