Mini Mill Sieg X2 to CNC and other modifications
gbravo
My home workshop
This is the CNC mill with the following improvements:
- Ball screw with double ball nuts and anti backlash adjustment in all three axis.
- Double bearing lead screw support.
- Reinforced column
- Stepper motors with timing belt transmission.
- Inferior base with support for reinforcement of column pivot.
- Balance system with gas spring
- Tapered gibs.
- 4th axis with harmonic drive.
Very cool! I finally decided that CNC was out of my budget for a while, and have gone the "Make it the best manual mill you can" route.
I like the tapered gibs... any more details about that mod?
Also, what are you using for the way covers? I like the "wrap over" design on them!
Those bellows are made myself with PVC reinforced fabric with web information like,
http://www.franksworkshop.com.au/CNC/Bellows/Bellows.htm
I dont make cuts in the the edges for fold the fabric, I only glue some strips underside the folds (from the same fabric ) with wide smaller than the fold size, leaving the upper interior edges free for aid the fold operation. Finally I clamp and press the folded bellows between two woods (like picture) and heat with hot gun and it maintains his form.
