- Jan 3, 2014
- 72
- 17
Hello,
I have a small mill (Sieg SX2).
I am unsure of the cutting speeds & feeds with this machine. The machine is much lighter than the two I have previously used.
Steel work:
Rocol cutting fluid.
Small diameter end mills, 6 - 12 mm,
Carbide tipped 20 mm, maximum size indicated for this machine.
I would like to remove chatter from the cutting.
Using medium rpm, lightish cut, slow feed has not worked.
is there a variation that may help?
Many thanks,
Dennis
Steel work:
Many thanks,
Dennis
