markstephens
New Member
- Mar 15, 2017
- 3
- 1
Hi,
OK, true confessions, I'm not building an engine... yet! I do think a Sterling is in the near future, but I need to begin somewhere and so I have a beginners question whose answer will hopefully lead to a mill purchase.
I'm creating a Rolling Ball Sculpture using wood, brass and glass marbles as the media. I'm pretty good at woodworking, but very new to machining.
My router table makes for a poor mill with the use of jigs and, as you can image, it's not very accurate or easy. The photo shows what I'm attempting. On the left is the raw stock, a brass pipe 1 5/8" diameter with 1/4" walls (also shown is a 1/8" rod used as track). I use a jig with a Dremel to cut off a 1/4" thick circle. A jig on the router table mills the 1/8" holes in the ring (next photo clockwise). The ring is cut into 4ths, a small flat made on the each of these track supports and a hole drilled into, but not thru, the flat. Add some solder and you get to the picture on the bottom right.: a marble rolling on a track in dire need of a clean up!
It seems to me a small mill with a rotary table can drill the 1/8" holes. Can I drill them down the length of a pipe and then cut the rings? That would save a lot to time. In either case, is the drill bit going to flex as it is only drilling a half hole?
Is there another way to add a grove down the length of pipe to avoid any flexing of the bit?
Also, can a mill with a saw bit cut the 1/4" rings from the pipe?
So... anyone want to convince me to buy a mill!?
thanks,
mark
thanks,
mark
