swordsmith
Junior Member
- Jan 23, 2013
- 2
- 0
I has been a long time since I first starting redrawing and scaling up the plans for this engine. It is a mix up of a few elmer designs built at double scale. 1" bore, 2" stroke and a 6" flywheel. I thought bigger was better, but soon realised mine and my equipments limitations. It was built with a H & F AL 50 lathe, hacksaw, hand drill, 4" angle grinder, die grinder and a set of files. Is nearly all made out of mild and bright steel. The finished engine with it's base weights a good 7 kilos. I was never very happy with the surface finish I could achieve or my accuracy. I have since found accuracy is found with patience. I have a lot to learn about machincing. I always seem to be wondering "how should I hold that" or "I really should have done that first".
I am really finding your build threads to be quite helpful. Seeing a lot of things I would never think of.
(hope I got the photo linked right)
Jamie
Jamie
