langstonshelby1950@gmail.
Does anyone have experience with the MicroLux® 7x16 Mini Lathe?
Thank you
Thank you
Hello Pete, I appreciate your answer. I am building small model engines, and that is why I have been looking into the smaller lathes and mills. It is challenging to find them other than made in China or Taiwan. I did find a bit larger lathe made in Italy. The only small lathe I can find made in the good old USA is Sherline Micro,, however it is really small.No hands on experience, but that's a whole lot of money for one of those mini lathes. Ok as the advertising says it has "true" inch based lead and feed screws, but I've seen nothing yet that mentions any actual improvements over some of the well known corner cutting, faults and inaccuracy's those lathes have. And fwiw, I've had the unfortunate experience of buying a 10" swing off shore lathe that was so poorly machined for it's basic alignments it never should have left the factory. Fortunately for myself, I did have the extra machine tools, experience and knowledge to re-machine those faulty parts back to where they should have been. Today I would never buy any lathe that didn't clearly advertise it actually comes with a proper test certificate, and verify those numbers myself as soon as I got it. That gives at least some buyer protection and a baseline the machine was supposed to be built and tested it's correct right at the factory. Not all of those test certificates can be relied on either. The numbers I could properly check with my Vertex rotary table didn't agree with it's factory supplied certificate of accuracy. But I finally checked those long after the warranty was up.
Any lathe below about a 10" swing will cost right about the same for all the additional tooling that's required before you can even use it. 10"-12 swing will also have almost equal tooling costs for lathes of that size. Frankly and after wasting a whole lot more than I'd like to add up, buying the largest and best optioned lathe with the features that are the most important for the work your planning on doing now or possibly in the future really is the most cost effective way to go. And because of that inevitable tooling cost, that initial price of any lathe is after a couple of years almost incidental. In my opinion, buying right now and what you can afford may not be the very best method. Being a bit more patient and saving for something a whole lot better will in the end be much more satisfactory. That in itself is a hard lesson to learn, and many seem to refuse to listen to advice like that.
I have had mine for close to 10 years snd have been happy with its performance. It is on par with the Little Machine Shop lathes, and since I got it on sale it was a good buy. It’s cleaner & tighter than other Seig 7x lathes, but is small: if I were doing it again, I’d go for a 9” lathe (and a Bench Mill instead of a Mini Mill).Does anyone have experience with the MicroLux® 7x16 Mini Lathe?
Thank you
I do not see much problem with a lathe from Taiwan in general, but you will have trouble to find a decent small machine.Hello Pete, I appreciate your answer. I am building small model engines, and that is why I have been looking into the smaller lathes and mills. It is challenging to find them other than made in China or Taiwan. I did find a bit larger lathe made in Italy. The only small lathe I can find made in the good old USA is Sherline Micro,, however it is really small.
Hi !Hello Pete, I appreciate your answer. I am building small model engines, and that is why I have been looking into the smaller lathes and mills. It is challenging to find them other than made in China or Taiwan. I did find a bit larger lathe made in Italy. The only small lathe I can find made in the good old USA is Sherline Micro,, however it is really small.
