After discovering I was getting pretty inconsistent readings with a cheap $30 ebay Digital caliper. decided I should invest in some decent measurement equipment.
I have read advice that old school vernier calipers and micrometres, no dials or electronics to go out of calibration are every bit as accurate as their electronic counterparts. would I be correct that if you have some accurate standards like gauge blocks or setting standards then you can simply verify and adjust your mechanical micrometres at home. with electronic,well aapart from sending them to a professional calibration service there is not much a hobbyist could do?
I nearly died at the price of some top brand of electronic calipers and micrometres but thought, the price of the mechanical ones are not too bad.
I'm thinking Mityutoyo because that seems to be the most readily available brand in Australia. Perhaps 200mm vernier calipers, 25mm and 50mm outside mics and to measure internal diameter simply use inside spring calipers and take the measurements off them with the micrometres? anything else I am overlooking?
