jasongetsdown
New Member
I have a Dalton lathe circa 1914. It’s a beautiful machine, but part of the compound slide is cracked. I would like to make a replacement, but I’m not sure what material I can use.
The part has a round pocket on the bottom that sits on a circular boss to rotate the compound, and on top are dovetails that engage with the top of the compound where the tool post mounts. All this to say it has bearing surfaces that I will be scraping in.
the original part is cast iron as far as I can tell. Not many suppliers sell cast iron, but there is a product called dura-bar that makes continuous cast gray cast iron bar stock. Problem is it’s expensive, about twice the cost of cold rolled.
So my question is, do I need to use cast iron? Can I just use cold rolled? Should I use something tougher like 4140? Can any steel be scraped like cast iron?
Thanks!
Jason
Thanks!
Jason
